| You can either have a clog (mouse nest or similar).. or your carbon canister and lines may be clogged.. It will cause the pressure from the gasoline fuel to push the gasoline back out where you fill it. I would delete the carbon canister and drain your tank.. who knows.. it could be full of water for some reason. Listen for your pump to prime the fuel pressure and also check for fuel pressure itself. Probably wouldn't be a bad idea to remove your pump and check the filter sock.. could be clogged up with gunk.. but if you check what the fuel pressure is.. it will kind of narrow it down
_________________________________________________________________________ ~~~ Sig starts below ~~~ =================================================================NO, This picture is not photoshopped.
AIM:Shawn300zxTT "-Any closeups on the nuts? - zboost(tx) 19:17:53 08/08/05 -Not really something you want to ask another man about... (n/m) - LordZ 19:24:00 08/08/05" "I just took 45 min and scrubbed the heck out of my rear" teambushido(San Diego, CA) 19:24:51 12/11/04 -1991 Stage _ TT 5spd (Upgraded to hell and back) -1990 Super White 2+2 Na Stage 3 Auto (Deceased :( ) -1990 Cherry Red Pearl ,Auto Coupe (Parts car) -1990 11 Sec Eagle Talon Tsi AWD, (SOLD!) -2001 Ford F-150 Crew cab, 5.4 Triton v8.. Tow bitch -1997 Acura 2.2 CL, 5spd. Daily Driver.. great little car! -2004 Honda CBR 600RR (Candy blue, FOR SALE) |
